gasket info
INCase
07-19-2007 13:40:38
FYI. I"ve seen a ton of different options and ideas on head gasket instalation in regard to sealers, no sealers, grease ect ect.... so I called Vickers about the #3103 gasket for my 800 Case. They said that gasket is to be installed dry. He also said 90% of their gaskets are dry install. FYI.
Flewster
07-20-2007 05:43:03
 Re: gasket info in reply to INCase, 07-19-2007 13:40:38
When I pulled the head off of my DC there are no orings around the oile passages nor the water. Is it suppose to have them?
Bob/wis
07-20-2007 07:54:02
 Re: gasket info in reply to Flewster, 07-20-2007 05:43:03
I am not sure about the older tractors but the 00's and 30's I know did have them.
Bob
Bob/wis
07-20-2007 04:48:11
But, what i love is when you have a old tractor leaking oil all over the place from under the heads. Then you pull them off only to find absolutely no o rings around th eoil passage or the water passage. Very good sign it was worked on with out a manula.
Bob
INCase
07-24-2007 12:44:37
 Re: gasket info in reply to Bob/wis, 07-20-2007 04:48:11
They are supposed to have O-rings. A full "top-end" gasket set should have them included.
