Mouse nest in radiator - how to clean?
Tim in New York
07-18-2007 19:41:17
Went to put the radiator back in my 700 diesel tonight and heard stuff sliding around when I picked it up. Turns out a mouse had built a nest in it while it was stored in the shed. I got out a bunch of stuff by shaking it upside down and running the shop vac in the upper hose port. Is there any way to make sure I got it all? Thought about laying it down with outlets facing up and filling it with water- will debris float to the outlets?
Tim in New York
Tim in New York
07-19-2007 14:12:57
 Re: Mouse nest in radiator - how to clean? in reply to Tim in New York, 07-18-2007 19:41:17
Thanks all for the advice. My shop vac is a cheapie, without an exhaust hose. But I will try my air compressor on it.
The radiator came back from the shop after cleaning and some soldering work - then I put it in storage, so I hate to send it back just for cleaning. Guess after the compressor I'll fill it with water and see what floats to the top.
Tim in New York
INCase
07-19-2007 12:09:09
if the nest is at the top, try turning it upsidedown and put the exhaust of the shop vac in the bottom hole (make sure the shop vac isn"t blowing dust out 1st. that may get most of it.
JGarner
07-19-2007 10:47:56
My 2 cents worth. Would you be money and time ahead to take it to your local radoator shop, have them remove the tanks and dump the trash out, then rod it out while you have it there? This way you would know its clean. I haven't had any radiator work done lately so this may be too costly. Just an idea.
JG
JGarner
07-19-2007 10:47:20
My 2 cents worth. Would you be money and time ahead to take it to your local radoator shop, have them remove the tanks and dump the trash out, then rod it out while you have it there? This way you would know its clean. I haven't had any radiator work done lately so this may be too costly. Just and idea.
JG
Walt Davies
07-19-2007 08:52:51
When I changed radiators on my LA a mouse had built her nest and had her pups in the top of the radiator. I didn't know this until it was too late and the darn stuff petty much plugged the whole system up. It took me a long time to get it clean I just kept running water in till it all floated up and out. Cooked mice aren't all that good to eat.
Walt
