Case 400 valves
VACLee
07-18-2007 19:21:21
Does anyone have a source for intake and exhaust valves for the 400 series(251 gas)engine. Case dealer was of no help on this one. Thanks Lee
Doc Larry
07-20-2007 04:46:17
 Re: Case 400 valves in reply to VACLee, 07-18-2007 19:21:21
I've got two extra intake valves, A7360, that I would part with if that helps.
Larry
Bret4207
07-19-2007 07:19:40
I'm working on an 811B now with bad exhaust valves. The guy at the shop originally thought he could get them without problems. Now we're down to putting in new guides and reaming them for a different size so he can use another size off the shelf valve. Might be worth looking into.
INCase
07-19-2007 05:19:49
There were some NOS 730 gas valves on ebay not too long ago. Not sure if they"re interchangeable or not. Some "Case" dealers aren"t too good they started life as IH dealers and never fully took to the older Cases. you may want to find another dealer. Look up Link type in 400. you"ll have to go thru the list as there are several things that were "400""s. you can use head parts from the big 600, 700, 800 and 900"s as well (old big 500"s too??) then tell the dealer what you want. goodluck
