voltage regulator
no deeres here
07-18-2007 18:28:32
Could anyone direct me to a source for a voltage regulator for a 510 B? I would like to keep the generator as it works very well. Case dealer says that the autolite number crosses up to a solenoid. Does that mean that I would have to go to an alternator? Thanks
case 320
07-20-2007 21:23:51
 Re: voltage regulator in reply to no deeres here, 07-18-2007 18:28:32
ps those votage relays have a lead fuse line in them( only !! if it melts on you while you polarize it )soder a coper line on the reg at the bottom of the inside box to the feild pole if it melts on ya* the armature tab is on the bottom of the reg not marked its not a ground the l stands 4 lights (internal problem )good luck
mEl
07-19-2007 04:32:25
The vr in question is superseded to a solid state unit but is available , or was at least to my best knowledge. they are good but not tolerable of any mistakes on your part in the installation, wrong polarity etc. Check with a good case dealer that has it together. mEl
case 320
07-20-2007 21:07:28
 Re: voltage regulator in reply to mEl, 07-19-2007 04:32:25
i had generator problems to after i swithched 6 volt poss ground to 12 volt pos ground i went to tractor suply co tsc they had a masseyfergenson 12 neg or poss ground votage regs it works great they also have 6 poss or neg ground regs to they run bout 45 dallers but they strapon to generator by use of the ground screws tractor supply co is place you wanna go ps i have to polorize it evry time i take the battery out its a pain but it works
