skid steer 1840 bucket control problem
John 163
07-18-2007 17:29:39
I have a case 1840 skid steer and the left bucket control lever is sticking. It does not spring back to the neutral center position. I have greased and sprayed every piece of linkage that I can find. I am wondering if I have a valve problem?
What do you think?
mEl
07-19-2007 04:26:52
 Re: skid steer 1840 bucket control problem in reply to John 163, 07-18-2007 17:29:39
If you are sure that there is no sticking or binding in the linkage then the detent for the float feature in the rear spool end cap is probably rusted or gunked up in the control valve, the raise spool is the only one that has it. it has 2 ball and spring detents which need cleaned & lubed. Remove the two little 7/16 flat nuts which hold the springs remove the spool cap clean or replace parts as necessary, lube with a good grease and reassemble.
