SC Crankshaft pulley and other questions
Ken Christopher
07-18-2007 05:39:22
Good morning all.
Well, Got the oil pump out of the block on the SC, the camshaft and crankshaft out. One problem. I did not pull the puller on the crankshaft, and took off the front cover and crankshaft as one unit. Not thinking I have to have the cover off to time it at reassembly. How does the pulley come off? As simple as a 3-jaw puller and some lube, or is there more to it? I noticed that there are a couple of almost like set screws in the journal on the backside of the pulley. Do these have to be removed?
Also, I cannot find a sleeve puller anywhere around for rent, or anyone that has one. I do not have the access to materials to make one. Debating on wether or not to let the local tractor shop do it. The only down fall is it is 75/hour do get it done. I hate to pay for something I can do myself, but I cannot justify spending $400 on a tool I may only use once! I have tried the hammer and block of wood, but maybe I just need a bigger hammer... ?
C. Amick
07-19-2007 09:19:21
 Re: SC Crankshaft pulley and other questions in reply to Ken Christopherson, 07-18-2007 05:39:22
Where are you located?
Ken Christopherson
07-19-2007 18:16:06
 Re: SC Crankshaft pulley and other questions in reply to C. Amick, 07-19-2007 09:19:21
I live near Minneapolis, MN. I would pay shipping costs if there is one I could loan from someone. If I was still in school It would be easy to make one in the metal shop, or if the teacher I had still worked there. He has since retired, and has taken a full time position in the military. The new teacher won't give me the time of day.
C. Amick
07-20-2007 16:40:20
 Re: SC Crankshaft pulley and other questions in reply to Ken Christopherson, 07-19-2007 18:16:06
I have one, but I'm in WV and it has a good bit of weight to it. Have you checked with Don Livingston (503-433-0073)? He is in Austin, MN. Call in mornings.
Larry Martin
07-18-2007 16:05:14
You can make a sleeve puller fairly cheaply with some All Thread rod, nuts and some scrap steel. Machine a plug for the bottom with a recess for the sleeve which will keep it centered. God luck.
Jeff McBride
07-18-2007 12:31:55
I guess I was lucky, my sleeves came out with the pistons.
caseman44
07-18-2007 07:24:55
Hi there, Yes, there is a pin in your SC crankshaft pulley, it is crosswise at the back of the pulley hub, clean off that area and you will find the pin head, just drive it out and the pulley comes off fairly easy. The pin might be tappered so see which side is bigger and drive out the smaller end of the pin. As for the sleeves, if you have the engine out of the tractor you can drive the sleeves out with a piece of Oak wood, laying flat on the bottom side and you will not damage anything. I live in Walnutport, Pa. and could remove them for you, but you are probably not close to my area. Hope this will help you. Sincerely, Caseman44 or Harold Ph # is 610-767-8370 if you need to talk more.
