adjusting breaks
grace white
07-17-2007 19:04:02
hi, i have a 51 case vac and i cant see how to adjust the breaks
Gene dotson
07-18-2007 08:17:11
 Re: adjusting breaks in reply to grace white, 07-17-2007 19:04:02
The brakes are adjusted by the 3 threaded plugs on the outside of the brake housings. There is a 5/16" bolt (1/2" wrench size) in the center of each adjuster to lock the adjustment. Loosen this, being careful not to twist it off if it is frozen. Next step is to turn the threaded plugs clockwise evenly till you have sufficient brakes without excessive drag, then tighten the lock bolts... Gene
