Transmission Done?
scott je
07-17-2007 17:43:53
I"m extremely green in the world of tractors but am a journeyman auto mech. I recently purchased a early 70"s(?) 930 comfort king with the 8 speed trans. and the other day shift it into hi gear and the shifter went loose and unable to move any gears.I was able to put it into gear manually but would jump out under any load. anybody have any ideas what it might be.
CNESLER
07-17-2007 18:29:27
 Re: Transmission Done? in reply to scott je, 07-17-2007 17:43:53
Scott
The Hi/Low range shifter has pins and links that will some time come apart or break where it is welded to the stub coming out of the transmission
remove the floor board and you will be able to see what is going on.
CNESLER
