VAC Hydraulic Cylinder
Jerry In Idaho
07-17-2007 16:00:12
I need the small hydraulic cylinder mounted to the left of the torque tube on my 1947 VAC. Case #VTA 2744. New, used, rebuilt or a useable alternative. Anyone know of a source??? Thanks for your help
Jerry W
07-21-2007 10:20:54
 Re: VAC Hydraulic Cylinder in reply to Jerry In Idaho, 07-17-2007 16:00:12
Jerry If you look among the items, one is in this pile now on eBay. 190132464251 If not I will sell one for $40.
Jerry
Jerry in Idaho
07-21-2007 19:51:13
 Re: VAC Hydraulic Cylinder in reply to Jerry W, 07-21-2007 10:20:54
I'll check out that sale right now..and thanks for the hint. I'll get back to you on your available part. Thanks a lot.
mj
07-20-2007 19:23:54
Use a brake cylinder hone to clean it up and then get an 1 1/2" fabric-reinforced piston cup seal from McMaster-Carr and you'll be good to go.
Jerry in Idaho
07-20-2007 19:45:49
 Re: VAC Hydraulic Cylinder in reply to mj, 07-20-2007 19:23:54
I'm afraid the cylinder bore is too pitted to clean up with a hone. It's really in bad shape. I may have to give it a try though. I've even thought about trying to find some tubing the right size and machining off the old tubing from the end, reweld, and rethread it. Thanks for your thought though....
mj
07-26-2007 08:19:47
 Re: VAC Hydraulic Cylinder in reply to Jerry in Idaho, 07-20-2007 19:45:49
I've got some cylinders if you need one.
C. Amick
07-20-2007 16:55:35
You might try Austin Farm Salvage in MO 660-679-4080 or keep watching on Ebay.
