Case 580 CK - Backhoe Hydraulic Line Replacement
Tunk Creek
07-17-2007 15:48:54
What is the process for replacing the 4 Backhoe lines that run from the control box down and up the BH arm. The bend thru the bottom of the BH attachmetn pin sure looks like you either have to drop the backhoe attachment completely or the pivot arm. At the angle the hose bends the hydraulic coupling will not slide thru the arm with the bottom protection plate.
drinderer
07-18-2007 13:48:46
 Re: Case 580 CK - Backhoe Hydraulic Line Replacement in reply to Tunk Creek, 07-17-2007 15:48:54
I just replaced mine. I had the backhoe seperated at the piviot, and figured i"d replace the hoses at the same time. I don"t think you would need to remove the backhoe jut lay it flat, and remove the protection plate. I was able to get the fittings thru. You will need a good 1 1/4 crowsfoot wrench to get the lines loose from the valves.
My supplier couldn"t find the bulkhead fittings on the 2 longer hoses, so I had them make the hoses 1 1/4" shorter with a female JIC and supplied my own 3/4" bulkhead union.
Tunk Creek
07-20-2007 09:11:12
 Re: Case 580 CK - Backhoe Hydraulic Line Replacement in reply to drinderer, 07-18-2007 13:48:46
Don't recall mine having a removable protecion plate. The plate may be part of the arm itself. Mine is an older CK mid 60's. Thanks for the info and I'll pick up the crowsfoot and check this weekend.
