Case 450 converter leak
Junkman
07-17-2007 11:22:52
Case 450 highlift has a torque converter leak. Anyone have any experience with them? Machine has been repowered with a perkins and home made bell housing. Torque converter is leaking out the bell housing. Machine moves good but is leaking. Anything I should look out for when removing the converter cover? Haven't found much help on crawler forum. Any sources for parts or repair in st louis area? thanks
INCase
07-18-2007 09:08:33
 Re: Case 450 converter leak in reply to Junkman, 07-17-2007 11:22:52
not sure about crawlers but if its built like the tractors the engine to bell-housing has a gasket that seals the unit. If it has a homemade bell-houseing I would guess its not true and flat to the engine and you"re not getting a good seal. Can you post pictures of this unit? I"d like to see how they repower it, out of curiosity.
