Case 870 Powershift
Brad Sherwood
07-15-2007 16:31:41
Got an 870 that has had the clutch rebuilt twice this year now. When starting out in low, the clutch squeals for awhile. but that lasted only a short period. Now, after starting the engine, when you depress the inching pedal, the engine stalls. Last time we were told that the C1 clutch pack was torn to pieces. Anyone have any ideas?
Tom (Ks)
07-16-2007 19:39:43
 Re: Case 870 Powershift in reply to Brad Sherwood, 07-15-2007 16:31:41
The C1 clutch pilot spool may be stuck open or the C1 clutch has failed again. Start engine and at the same time observe C1 pressure on a gauge. There should be no pressure (clutch down). If pressure appears, C1 pilot spool is open and engine will stall. If no pressure appears and engine stalls, C1 piston is stuck or damaged. With damaged C1 clutch, engine will run with clutch pedal up in low and second, but will stall when shifted into high.
