Power shift problem
Tammy2411
07-15-2007 16:01:44
Have a 2090 Case tractor that was working fine a few days ago, went to put it into reverse and wouldn"t work. The powershift gears 2nd and 3rd don"t work at all either. only the first gear in powershift works. does anyone have any suggestions on what the problem is or why this is happening?
Brad Sherwood
07-15-2007 16:17:38
 Re: Power shift problem in reply to Tammy2411, 07-15-2007 16:01:44
I had something similar happen to a Case 870 this year. On the control valve assembly, one of the plugs that pushes on the spring for the C2/C3 valve had backed out. Inspect the valve assembly for anything obviously wrong. check the test ports for 180 PSI. Refer to on IT repair manual for more specifics. Or call your dealer. good Luck.
Brad
