head gasket for case g188b
charles Graydus
07-14-2007 11:21:33
Help!
Does anyone have access to an electronic file detailing the bolt tightening pattern and torque specs that they can send me. I have help available for 2 days only and I want to change the head gasket on my Case 580. It is a gasoline engine, 4 cyl, G188B.
If you can help and if you have any tips on ths procedure I would greatly appreciate your input.
Jim B
07-15-2007 19:31:03
 Re: head gasket for case g188b in reply to charles Graydus, 07-14-2007 11:21:33
Don't have a pictorial an offer... but the sequence should be like most any head-bolt torque procedure... Start in the center and work alternately toward the ends of the head. Tighten progressively, in 3 or 4 steps, toward the torque spec.
As the 188 is an all cast iron engine, retorquing after warm-up is also desirable.
How about it... you experts out there... please confirm this is correct.
Roger (Mi)
07-16-2007 18:21:58
 You're absolutely correct in reply to Jim B, 07-15-2007 19:31:03
Right on!
