leaking tranny seal on case 430
kdok44
07-14-2007 08:02:49
Hi does anyone have any tips on the best way to change the seal from the transmission to the brakes. the one thats held in the bearing carrier. I took it all apart put a new seal in the bearing carrier i put it so the rubber was facing out and the steel was facing in? think thats right. then i put the bearing carrier in snugged it down and filled it up it seemed to be working but when i drove it it leaked worse. so today i took it apart and the seal is all tore up i must have tore it putting it in when i snugged it down its hard getting that bearing carrier back in i think is the problem. Anyways any help would be great. also as to which way the bearing is suppose to face that slips my mind...
brad;ey martin
07-14-2007 18:16:36
 Re: leaking tranny seal on case 430 in reply to kdok44, 07-14-2007 08:02:49
The rubber lip on the seal should be towards the oil, i.e. towards the transmission. The number on the seal will be visible to the outside. Be sure to grease the seal well before installing. It also helps if you have(make yourself out a sheet metal) a sleeve to slip between the seal and the pinion shaft as you slide the bearing arrier into position,
