tractor case 1958 help please
gossou
07-14-2007 07:15:52
first,excuse my english is not so good.i just buy a tractor case 1958 ,i already got problem lifting the front bucket hydraulic oil leak,will fix ,but don t really hnow where to fill the oil,which model of case a got no plate with serial number will try to put a photo soon,and where a could get information or service manual,seeing a place near the driver seat could it be where to filling the hydraulic oil
thanks
sbp
07-14-2007 08:29:12
 Re: tractor case 1958 help please in reply to gossou, 07-14-2007 07:15:52
fill the loader with oil on either side of the loader support arms, the biggest part. thats where the oil is. there is a drain plug at both sides on the bottom by your feet on the inside. the filler is at the top on the outside. they are plumbing type threaded plugs. you are supposed to drain the oil now and then. use 20 wt motor oil
