hydro light/buzzer
Jesse Robertson
07-13-2007 12:19:29
Hi I have a 92 case 1840 and the hydro temp light and buzzer comes on. Some times it takes a few mins and sometimes it will take a hour or so. I have changed the fluid and the filter And it still goes off. could this be a short in the wiring? thanks.
mEl
07-14-2007 05:38:35
 Re: hydro light/buzzer in reply to Jesse Robertson, 07-13-2007 12:19:29
Take up your floorboard, check for a sender on the pipes on the hydro unit, disconnect the wire and tape the end so it can't short and if the problen stops replace that sender. if still a problem check for wires rubbed thru, have had an occasional dash problem so keep that possibility open. mEl
