Transmission Trouble
Richard E.
07-13-2007 11:46:19
I have a 731c diesel,8 speed case-o-matic. It acts like the shaft in the 5-8 has set up(the tractor won"t move) it will stall the engine when put in direct even without putting it in gear. Does this tractor need to be split ? It will move in 1-4 high-low and reverse. The pto still works. Any ideas would be appreciated. Thanks in advance, Richard.....
caseman44 or Harold
07-25-2007 04:07:22
 Re: Transmission Trouble in reply to Richard E., 07-13-2007 11:46:19
Hi there, Richard! Just thought I would drop you a line, I have 3 Case 400 Racine tractor rear and trans. for parts, they also have the 8 speed transmission, they might be the same parts as your 730, two of these tractors had the diesel engines in them. I am in Penna. Let me know if I can be of any help.
Richard E.
07-29-2007 10:32:45
 Re: Transmission Trouble in reply to caseman44 or Harold, 07-25-2007 04:07:22
Thanks , I'll keep you in mind. All it is, is the oil slinger has failed spoiling 2 bearings . I'm in the process of "trying" to get into the bottom of the transmission to re-place it, It's a plastic gear ! Hopefully I'll get it apart this week ! Richard.....
Richard E.
07-14-2007 08:28:19
Thanks guys for getting back so quick. I have a I&T shop manual and was hoping someone might have a secret way of fixin' it without spliting it. It looks worse of a job than it really is with all the stuff to take off so I can get at it, I know, Its not gonna be easy by any means. Thanks again, Richard.....
Roger H
07-14-2007 05:32:39
Exact same thing happened to my 930, had to have local mechanic tear into it & replace a couple gears. I didnt have the 930 but a short time when it happened but when I got it, it was low on transmission oil & I"m almost certain that caused it even though I changed trans. oil right when I got it.....Yes you would need to split it.
mEl
07-14-2007 05:20:35
ck for a seized gear in the dual range section up in front of the 4 speed tranny. could get messy, have had to cut them out with a bluewrench.
