dc clutch
neattapuller
07-12-2007 19:34:23
I have a 53 dc with a foot clutch seems to slip when trying to pull in second gear or higher first gear it doesnt slip . I cant find any adjustments other than the rod to the peddle . Should I just replace the clutch?
neattapuller
07-13-2007 18:48:27
 Re: dc clutch in reply to neattapuller, 07-12-2007 19:34:23
do you have a name and number for the clutch guy in mo?
C. Amick
07-13-2007 09:20:21
Since it is a wet clutch lubricated by oil from the engine, could you have a bunch of sludge build up? Cleaning it with some diesel fuel may not help, but it couldn't hurt if you looking at a tear down.
J heitkemper
07-13-2007 04:27:25
Not yet , Remove side plates on bell housing , Locate push pins on flywheelclutch pac , Earlier models had pull pins similar to the PTO clutches on other live power CASE tractors , Anyway with pin depressed spin the clutch pac in a manner that tightens the clutch , Trial and error is how I do this ,Good Luck ,Jim
DKase
07-13-2007 06:14:50
 Re: dc clutch in reply to J heitkemper, 07-13-2007 04:27:25
Sorry, that only works on hand clutches. The foot clutch is a spring clutch with no adjustment other than the pedal position. Don't be surprised if you find your pressure plate cracked or broken. There is a clutch rebuilder in MO that has stiffer springs that help a LOT. Clutch disk might be warn thin also. It will have to be split to do much with it. Good Luck DK
J heitkemp0er
07-14-2007 04:47:19
 Re: dc clutch in reply to DKase, 07-13-2007 06:14:50
I Stand corrected , Never had to do anything to the foot clutchers Around here yet , But have done some to live power hand clutch models ,I reasoned they were the same animal ,, Jim
