hand clutch on Case 300
Lincoln
07-12-2007 18:45:39
Was using my 300 to mow hay today. Went to disengage the hand clutch and something broke inside. The lever is no longer conected to anything inside the trasmission, and the lever will slide out of the case about four or five inches, but not come out all the way.
I quessing I sheared the pin that holds it to the throwout yoke. The woodruff key is keeping it from coming all the way out of the case. Will I be able to fix this from the top of the triple range gear box, or will it have to be split.
On the bright side it broke while engaged, and the seal around the lever was leaking anyway.
J Heitkemper
07-13-2007 04:21:38
 Re: hand clutch on Case 300 in reply to Lincoln, 07-12-2007 18:45:39
From my memorey ,You are correct on all counts ,No tractor split , I helped with this repair on a 530 when I was in the 8th grade , that was over 35 years ago , An I T book may be helpful , Sooner or later I may have to do the same 430 that wandered in here a couple years back ,,Good Luck ,Jim
wayne2
07-12-2007 19:34:46
Mine dosn't work at all-but I'm a stump farmer-till I got my Excavator-She's round nose 3/4 rubber (wife like's her) named grandma-OH WELL-got six log chains to hoook uppppp!!!! Wayne
