case 600 spun rod
j kuhn
07-11-2007 19:34:18
I just bought a case 600 it has a spun rod bearieng on #6. Iv been reading other forum and this seems to be a common problem. Does anybody have any idea why.
Caseman44 or Harold
07-25-2007 04:22:44
 Re: case 600 spun rod in reply to j kuhn, 07-11-2007 19:34:18
Hi there fellows, I have a 500 Case tractor that has a spun rod bearing on #3 journal. I never got time to get into this tractor yet, I have the tractor for about 4 years. Its a shame for the tractor, it has a pair of almost new Armstrong rear tires, they are 30" tires, it has powersteering and the rear fenders are decent, has a mint grille and hood. I bought another used crankshaft for it that looks real nice. I might sell the tractor if anyone has an interest give me a shout. Sincerely, Caseman44
caseman-d
07-25-2007 20:32:21
 Re: case 600 spun rod in reply to Caseman44 or Harold, 07-25-2007 04:22:44
Caseman44 or Harold said: (quoted from post at 04:22:44 07/25/07) Hi there fellows, I have a 500 Case tractor that has a spun rod bearing on #3 journal. I never got time to get into this tractor yet, I have the tractor for about 4 years. Its a shame for the tractor, it has a pair of almost new Armstrong rear tires, they are 30" tires, it has powersteering and the rear fenders are decent, has a mint grille and hood. I bought another used crankshaft for it that looks real nice. I might sell the tractor if anyone has an interest give me a shout. Sincerely, Caseman44
Where you located at?? I used to have 2 500 for parts but let them go for nothing. One had a spun bearing and other one had bad pistons. Had a 600 also with bad bearing, never pulled the pan to investagate it. Was hoping to fine a cheap 930 with a good engine but sold the 500's and 600 before I found a 930. Then a found a 930 but didn't have the 500's or 600 anymore. Guess thats the way it goes sometimes.
caseman-d
D-C-741
07-13-2007 08:12:54
I have one that spun a Bearing, [never checked]this was 10 years ago,it now sets in the Weeds,thinking of selling or parting it out ?just have not made up my mind.
Junkman
07-13-2007 09:57:17
 Re: case 600 spun rod in reply to D-C-741, 07-13-2007 08:12:54
dc741 if you decide to sell, i would be interested. Where are you located?
Ande
07-13-2007 05:01:16
Personally I would pull the pan at 5000 hours and replace the bearings,it will save alot of headaches and give you some peace of mind
Use a good grade of motor oil and change every 100 hrs or yearly
Ande
j kuhn
07-13-2007 19:47:08
 Re: case 600 spun rod in reply to Ande, 07-13-2007 05:01:16
Iv heard alot of the problem is that it has a wet cluth wich is fed oil by the engine and if your cluth is slipping or not adjusted tight that all that loose friction material will wind up back in your engine.
DKase
07-12-2007 12:56:54
My 830 did that about 15 years ago. It had always been serviced regularly, but it had 15,000 hours on it and never had the pan off. It was shot end to end. (Steering, hyd. PTO, range shift gears, seat suspension, and tires.) It was not worth fixing. I pulled the pan for the fun of it. Found all the tabs on the bearings almost worn off. New bearings should go in every tractor by 8000 hours.
1200 TK
07-11-2007 21:15:23
J.Kuhn,
You mention about your "CASE" "600" tractor that has a spun rear con rod bearing.Personally I have not heard of this with a "600". Further to that the crankshaft in any "CASE" engine was not prone to any problems. They are all built like the proverbial S -- house, I would say the cause is more likely to be to poor maintaince some where along the line, either not changing the engine oil or the filter at regular intervals including the air cleaner e.g. 120 hours. Hard work has never hurt a "CASE" engine !!!
Regards
Alan T. Lewis Christchurch. NEW ZEALAND
