DC 4
pete s
07-11-2007 18:13:59
I am looking at a dc 4,it needs a ring gear for it to start correctly,and one rear rim and tire,which is no big deal,but,is it quite a job to do the ring gear?Is the ring gear reversable?The rest of the tractor seems good,i can get it for 700.00.Think its going to make a good anniversery present for my wifey..Thanks and wish me good luck lol
pete s
07-15-2007 11:24:11
 Re: DC 4 in reply to pete s, 07-11-2007 18:13:59
Pete here went and took a 2nd lok with some tools,it seemed to skip,and on further inspection I found that it had just about no compression on #2,I had one years ago that would skip untill it went under power than ran fine,turns out it had a bad exhaust valve spring,and ran great ever since.This one wont do it
C. Amick
07-12-2007 09:18:20
Replacement ring gears are available. I think Don L. ([email protected] or 507-433-0073 mornings in MN)sells them.
wilson
07-11-2007 21:33:24
easy to split with 3/4 inch splitting pins just support under engine and slide back ring gear is less than $50.00 dollars at checker auto wising their warrier (sp) catalog can give you part number is needed
