Torque Tube?
bjr
07-10-2007 11:50:56
I'm not a novice, but I don't know what you mean by torque tube. What part are you talking about? I'm not familar with that term. bjr
Joe (Wa)
07-10-2007 12:26:50
 Re: Torque Tube? in reply to bjr, 07-10-2007 11:50:56
The torque tube is the transition piece (housing) between the engine and the main transmission. The front is the bell housing that bolts to the back of the engine and the rear bolts to the transmission at the junction just in front of the transmission shifter cover.
The torque tube is enclosed by the seals on the main drive shaft & hydraulic pump drive shaft at the front and the blind front of the transmission and drive shaft seals at the back. It is used for the hydraulic reservoir and also houses the hyd pump, drive shaft with bearings, and if the tractor is so equipped the optional triple range gear train and optional hand clutch assembly.
Joe
