case 133 baler help
I LIKE MY CASE
07-10-2007 09:14:25
I've been running my 133 for about 5 years and it does a good job. I need some advise on wear blocks as mine were worn out, I tried to replace them with hard (at least I thought they were) 2 x 4's - after about 500 bales they had worn down about 1/4 in. Does anybody know where to find these or what type of wood to make them out of. Or I had thought of using angle iron with a layer of poly on the bottom. I started out using sisal twine and swithched to poly as I was told it causes less wear on the baler - I don't think the poly slips off the fingers as well so I get some broken bales - what would you use? I fear she's getting to the end if I wear some parts out. I'm getting pressured (by mom) to get a newer baler (safety of starting motor) but it's so simple to work on - just enough capacity to put one on rack (me) one on tractor (wife or brother).
craig bunting
07-11-2007 19:32:38
 Re: case 133 baler help in reply to I LIKE MY CASE BALER - DO, 07-10-2007 09:14:25
Back in the early 70's when I was too little to buck bales. My job was to walk along side of the old Case baler and wave at grandpa when the old baler missed a knot. We would stop and tie it by hand before it left the shute.
I think many problems of the world would not occur if 9 year olds felt like they had a real mans job, and spending many hours walking in the sun with freah mowed hay and watching barn swallows catch bugs.
So you need a 9 year old boy on your hay crew.
george md
07-10-2007 21:52:39
I had a 133 back about 1960 and used it for many
years,only reason I traded it was to get one with
a thrower , bought a NH hayliner 67 , other than the thrower it was not a step up.
I think Charles is right on for the wood , you
might even think about boiling the oil while soaking the wood.
As for the missed bales , you should look at the twine holding discs . If they are worn they will not hold poly as well as they will hold regular twine. I used poly when it came out in the middle 60's, missed many bales the first day , put in new discs and problem went away.
The one I had was a PTO model, pulled it with a DC with live power . In a fair sized windrow it would work two guys on a wagon real hard. That baler would make nice straight square bales (and tight) not those bent ones the the IH 45 made back about the same time .
george
Charles Santhuff
07-10-2007 09:56:14
If I remember correctly, the blocks were made of hard maple and soaked in oil.
