Case 446 oils.
gold-leaf-deere
07-09-2007 15:55:47
What type of oil goes in the differintel and does the Hydraulic transmission use the same reservoir, or is there a seperate one, if so what type oil does this section use? This is a 1976 446, Thanks.
NCCub
07-09-2007 17:53:17
 Re: Case 446 oils. in reply to gold-leaf-deere, 07-09-2007 15:55:47
FOrgot to mention, the 15W-40 engine oil just runs your hydraulics, the gear oil should have a set screw in the rear to check the differential fluid.
NCCub
07-09-2007 17:50:53
Case 446 garden tractor (16 hp onan?), 15w-40 or 20w-40 engine oil for your hydraulic resovor, 90 w gear oil for you differential.
Kerry
