LA Case Brakes
Jim Bray
07-09-2007 11:25:01
I recently looked at an LA Case, supposedly manufactured in 1944. It did not have differential brakes, and I think it had the three speed transmission of the model L.
Can someone clue me in? Did Case make some LA's without differential brakes and model L transmissions?
If so, when did they convert the LA to differential brakes and four speeds?
Gene Dotson
07-09-2007 16:31:29
 Re: LA Case Brakes in reply to Jim Bray, 07-09-2007 11:25:01
The tractor may have been built during the war with steel wheels. If so, 4th gear was locked out to prevent excessive speeds for the steel wheels. Yours may or may not have the lockout removed. Try the shifter in the middle position and shift it down to see if 4th gear is there. It will not be marked if built on steel.
Turning brakes were optional on all LA'S. Hydraulic brakes were first offered in 1948 as an option, as were mufflers.... Gene
Walt Davies
07-10-2007 18:18:47
 Re: LA Case Brakes in reply to Gene Dotson, 07-09-2007 16:31:29
My 45 LA has the 4th gear mark but when you engage it nothing happens some day when I have nothing to to I will pull the top off to see if I can get 4th working I have a 48 LA as parts tractor.
Both of mine have brakes on the rear wheel hubs one is mechanical linkage the other is hydraulic.
Walt
1200 TK
07-09-2007 15:23:10
Hello Jim Bray,
I noted with interest your querie regarding your "LA"., which you say was built in 1944.
You ask about CASE building any "LA's" with three speed transmission, the answer is NO as they were all 4 speeds.
Now to the brake question - CASE used two types of rear wheel brakes (both factory options) straight out mechanical in rear hubs, drum type.
And also hydraulic brakes again in the rear wheel hubs. What is the tractor's Serial No ??
Sincere regards
Alan T. Lewis
Christchurch
NEW ZEALAND
Tom Railsback
07-09-2007 19:04:28
 Re: LA Case Brakes in reply to 1200 TK, 07-09-2007 15:23:10
To amplify Alan's post:
Mechanical turning brakes were an option prior to tractor 5208165; (I've seen tractors without turning brakes of that vintage.)
Hydraulic brakes were available from 5208165 through 5418606;
Differential brakes were standard beginning 5418607.
Source: My LA parts book that I've had since 1973 (given to me by an old Case dealer, no less.)
