Case 400 Diesel
Toby Harter
07-08-2007 18:49:47
My uncle recently gave me his 400 Diesel. I was wondering how long these were made and what it would be valued at. I am going to overhaul the motor this winter as it has a knock and give a lot of love. Anything you have I'd appreciate.
Moline_guy
07-08-2007 20:35:34
 Re: Case 400 Diesel in reply to Toby Harter, 07-08-2007 18:49:47
They are a great tractor, dad has had one on a loader for forty years, just can't kill them. Never done anything with the bottom end but we have sleeved it four or five times, and replaced a few shift forks, easy to work on and if it has the eagle hitch you can use it for anything, good luck with it.
Don Rudolph
07-08-2007 20:01:33
Congratulations! A 400 is a great tractor. They were made from 1955-1957. At the end of the run there were about 1400 Super diesel 400's made. The earlier 400's had almost exactly 50 hp and the Super diesels had about 55 hp. You can get the Super diesel performance by using 4 1/8 pistons (I believe you can even go with 4 1/4") and turning up the pump a bit. I would guess it would be worth around $1500 in the shape its in, depending upon tire condition and if it has an Eagle Hitch. Good Luck!! Don
Jim from Calif
07-09-2007 09:11:15
 Re: Case 400 Diesel in reply to Don Rudolph, 07-08-2007 20:01:33
Don:
I have been researching Case data trying to identify the number of Super's built. Please provide me the source of your 1400 number. Thanks
Don Rudolph
07-09-2007 17:34:26
 Re: Case 400 Diesel in reply to Jim from Calif, 07-09-2007 09:11:15
I believe I got the number from Ross Richwine, who knows more about 400's than anyone else I have ever met. His e-mail is [email protected] and he is a great guy. Don
Doc Larry
07-10-2007 05:57:04
 Re: Case 400 Diesel in reply to Don Rudolph, 07-09-2007 17:34:26
You may already know this, but the 400 super started with serial 8106131, so if you can track down the last serial number you might have a pretty good figure.
Larry
