How much of the old SC (48) will interchange with the VAC?
TUK101
07-07-2007 15:35:11
I blew the clutch out of my VAC tractor and found an 1948 SC series of tractor and was wondering how interchangeable they are?
j heitkemper
07-09-2007 19:59:14
 Re: How much of the old SC (48) will interchange with the VA in reply to TUK101, 07-07-2007 15:35:11
Ditto on all comments , sorry Guys ABOUT THE ONLY thing THAT THE SC AND VAC WILL MATCH UP IS IN HORSEPOWER PERFORMANCE , TIME AND AGAIN , THE VAC WILL KEEP UP WITH THE SC , AND CASE brA$$ went out of their way to keep a lid on this spirited little tractor , , Mr. watson , How is the DC 4 ,you have over there ? .,, See ya , Jim
watsonsgotit
07-11-2007 16:41:48
 Re: How much of the old SC (48) will interchange with the VA in reply to j heitkemper, 07-09-2007 19:59:14
Jim,
You must be talking about the DO I have sitting in the yard. Changed out the motor and haven't got it all back together yet. I had it stored in the bottoms and decided I better haul it home the other day. It's in line, maybe we can get around to it in the next few years.
C. Amick
07-09-2007 09:19:40
The VAC and the Moline R have more parts in common than do the SC and VAC. The air breather pipes on the VAC and SC are not the same. In 1948, the Moline and VAC used the same steering wheel and hydraulic pump and possibly a few other parts were the same.
watsonsgotit
07-09-2007 18:03:55
 Re: How much of the old SC (48) will interchange with the VA in reply to C. Amick, 07-09-2007 09:19:40
You know I went back and checked on the air breather pipes. You are correct they are not the same. The SC is identical to the vac only taller. A SC air breather pipe could very easily be cut down to work and be correct for the VAC. The VAC air breather pipe will work on the sc but will be shorter. The clamp that holds the air breather pipe to the manifold is also similar but not the same. The VAC is flat where the SC has a ridge in the center. It would still work in a pinch.
C. Amick
07-10-2007 05:23:06
 Re: How much of the old SC (48) will interchange with the VA in reply to watsonsgotit, 07-09-2007 18:03:55
If you ever need one, I had a local muffler shop bend me some air intake pipes on their exhaust pipe bending machine. I took an old one in for them to use as a pattern. They are heavier than the original.
watsonsgotit
07-08-2007 18:20:19
The air breather pipe is the same. I believe the steering wheels are different diameters but will work in a pinch. Save your self the trouble and take the clutch to your local clutch shop and have it rebuilt.
CENTAUR
07-07-2007 19:48:28
Do you have a license to use that stuff? CENTAUR
TimBinWV
07-07-2007 17:11:41
There may be a few nuts and bolts that would work,if needed...other than that,they're entirely different machines..
BarryfromIA
07-07-2007 19:48:02
 Re: How much of the old SC (48) will interchange with the VA in reply to TimBinWV, 07-07-2007 17:11:41
Maybe the front tires. The two tractors were designed and built by different divisions in different cities by the same company.
