Case 580C Shuttle Shift
kenlc3
07-07-2007 12:28:58
I have an 1977 Case 580C with a shuttle shift and Hydrostatic transmission. My problem is it looses all Torque to move forward occasionally. It won't move at all at times. Then a week or so goes by and it runs fine. Other times it will go forward but has no power. If I go to drop the bucket to scoop up some loose dirt it doesn't have the power to move forward. Reverse is working perfect. All kinds of power. I have noticed something else. When I have the rear tires off the ground to use the back hoe. the tires move forward constantly. If I shift to reverse, the tires abruptly change directions. There seems to be no neutral. Any help or suggestions would be greatly appreaciated!!
Ken
STEVE SCHMITTGENS
07-10-2007 12:57:57
 Re: Case 580C Shuttle Shift in reply to kenlc3, 07-07-2007 12:28:58
Call me @ (314) 966-6692. I can tell you exactly what is wrong with your machine and how to fix it.
Thanks, Steve
WV Ike
07-07-2007 22:39:19
Chances are your shuttle is not working right. The shuttle has clutch packs similar to a John Deere Power Shift transmission. The rear end is actually a trans-axle. Is there any clanking noises coming from the rear. My 580C did the abrupt tire change before the pinion went out of the rear. If your shuttle is bad you're looking around the 2K plus mark to fix it. If you need parts I'd go to brokentractor.com I know he has a 580C he's parting out right now. If your rear end is good and you don't want to fix the other problem and are looking to get rid of your machine let me know I may be interested. My rear is still out. Have a great day.
kenlc3
07-08-2007 08:04:00
 Re: Case 580C Shuttle Shift in reply to WV Ike, 07-07-2007 22:39:19
I don't have any clanking noises. I am looking to sell this machine but I was hoping to fix it so I could get my investment back. I havn't a clue what I could get for it right now.
WV Ike
07-08-2007 18:39:14
 Re: Case 580C Shuttle Shift in reply to kenlc3, 07-08-2007 08:04:00
Where are you located at and what are you looking to get out of the ol girl. My email is [email protected] if you'd like to drop me a line there. Have a great day.
