400 project
Jim McVay
07-06-2007 15:57:42
I bought a 400 a couple years ago and am now getting around to working on it. The gas engine had a bad crank so I took it out and installed a used diesel in it. I was not happy with it so I got another used engine and tore it apart and all was good just needed a vavle job and new rings, bearings and seals. OK now the engine is completely torn apart. While I was running it I also heard a noise in the tranny I did not like. So I took the covers off. I found the gears were worn to the point that they were flaking the shinny steel part of the gears. So I got a 400 orchard rearend out of the back lot. I was going to swap out axles and use it.After getting the oil drained I found someone had broken A hole in the bottom of the case and bolted a patch over it. So now I'm taking the 400 orchard traany apart and plan on swapping the parts needed. What A project. I must be NUTS.
Christian Butler
07-07-2007 16:25:58
 howmuch horse power in reply to Jim McVay, 07-06-2007 15:57:42
i have a case 411-B-H how many horse power is it
joecool
07-07-2007 03:32:00
 Re: 400 project in reply to Jim McVay, 07-06-2007 15:57:42
have some fun, put in a 336, with turbo and have some real fun. a non turbo 336 is alot of power
screamin eagle
07-10-2007 12:22:18
 Re: 400 project in reply to joecool, 07-07-2007 03:32:00
Does the 336 engine have the same block mount? Have you repowered a 400 with the 336? I want to tractor pull with a 400 and am looking for ideas.
WV Ike
07-06-2007 21:59:05
My 400 row crop was sunk in the mud up to the rear axle. I'm not sure but I think it's a demonstrator so it's worth the time. If this was an easy hobby everyone would do it, but it sure is a fun one.
Don Rudolph
07-06-2007 20:38:05
Jim,
I can sympathize with you. The DCS I brought home was a complete piece of junk (according to everyone at the auction where it can from)and took a major effort to get it running again-only problem is it has 3 speeds in reverse and 1 forward! We just started tearing it apart again to replace the tranny. It must be some kind of disease. A wise man once said "you can never have too many Case tractors". Don
Scott KY
07-06-2007 19:12:53
If it was easy everyone would do it.
