Case La
Mark in Iowa
07-05-2007 16:48:51
I read about everthing thats posted here....get alot of information....THANKS... Was useing my La and the STARTER wouldnt ingage...took it off and ALL seem good so put it back on ...it work....Don't know what I did or didn't do ... My Question....is there suppose to be a gasket between the starter and bell houseing ??? If so Where can I get one ??? Like I said before ..This is the BEST format to get answers and LEARN alot... I do APPRECIATE any and ALL information....THANKS.....Mark
Gene Dotson
07-08-2007 16:48:13
 Re: Case La in reply to Mark in Iowa, 07-05-2007 16:48:51
LA uses an o-ring around the starter for a seal... Gene
Walt Davies
07-07-2007 08:19:22
There is a 1/4 in. thick cork gasket between the starter and the case. You can easily make one from cork that you get from the auto parts store.
Walt
Fergus
07-06-2007 05:27:36
As I recall, there is a rather thick, wedge shaped seal that goes in there between the starter and bell housing. Wet clutch, hence the oil seal.
