6128A head with MW dome pistons
dboll
07-05-2007 04:56:40
anybody know if dome pistons can be run with a propane head, once was told they would hit since have been told they will clear. I have 110 octane gas so thats not a problem.
dboll
07-06-2007 04:51:13
 Re: 6128A head with MW dome pistons in reply to dboll, 07-05-2007 04:56:40
DC puller, I tried emailing you, I did sell the crank, thanks for inquiring.
DCPULLER
07-05-2007 19:22:46
Doug, I bought an engine that had the lp head and domed M&W,s. They used this tractor for several years until a rod started knocking. When I tore the engine down there were alot of nicks in the pistons. Detonation is my guess, higher octane gas would take care of that.
dboll
07-05-2007 17:02:36
have a 5505 on now was wondering about raising comp. ratio, my CC is around 11 to 1 or more
joecool
07-05-2007 13:20:14
I wouldn't try a dome with that head. very small combustion chamber. use a 5505 or flat top piston.
wilson
07-05-2007 08:57:20
place straight edge over top of block. If dome is above block don't try it
dctom
07-05-2007 06:10:32
HAVE BEEN TOLD IT WILL WORK, I HAVE ONE BUT HAVENT TRIED IT YET, DONT NEED ANY MORE POWER YET AND LIKE THE LUG IT HAS NOW TOM
BarryfromIA
07-05-2007 17:02:53
 Re: 6128A head with MW dome pistons in reply to dctom, 07-05-2007 06:10:32
I have seen a DC CASE start the mechanical sled at a fast idle. Thats pretty cool when the m's would rev up the engine to full throttle and lift the front end to start out.
