Bigger Injectors for 600 Case
Rhaze
07-04-2007 21:12:15
We have just overhauled our old 600 Case diesel and we are wondering if there is a bigger injector tip that will work in these old bosch injectors?? The information we have does not give us injector tip size and we were wondering also if the 930 or even the 1030 used a bigger injector tip. We're assuming that we have to use this type of injector with these powercell heads. We have the injection pump turned up as much as it can go but we would like to find some more power without having to go to a bigger pump. Thanks for your time guys.
caseman-d
07-06-2007 20:38:48
 Re: Bigger Injectors for 600 Case in reply to Rhaze, 07-04-2007 21:12:15
If you really want to wake up the 600 find a inline pump off a 59 900B (930 may also work). There was a guy that put a inline on a 500 and that really made a puller out of it.
caseman-d
Thad
07-06-2007 11:08:57
In my opinion bigger injectors wont help you. The injectors you have now are letting the fuel your pump is pushing go thru them. You could try a set from a 1030 but if you dont have enough fuel going thru the tip to atomize correctly. You will hurt your self more than you gain. The 1030 injectors probubly actualy dont have that much bigger hole size. Thats my two cents worth. Thad
