sc hand clutch
Rags
07-03-2007 13:44:21
I have a 1952 sc that has the hand clutch lever on the left side when sitting on the tractor.Is this an odd ball? It`s the only one that i`ve seen like that.Thanks Don.
watsonsgotit
07-03-2007 18:03:50
 Re: sc hand clutch in reply to Rags, 07-03-2007 13:44:21
If I am not mistaken, when the eagle hitch came out in late 51 the hand clutch was moved from the right to the left on the SC's. They were on the left then until the foot clutch models came out in 54.
streaker
07-03-2007 14:55:54
I have a 1950, the hand clutch is on the right.
Jeff McBride
07-03-2007 14:25:13
All but the very newest ones are like that.
Larry in Mol
07-03-2007 13:56:39
Nope.
BarryfromIA
07-03-2007 19:33:05
 Re: sc hand clutch in reply to Larry in Mol, 07-03-2007 13:56:39
Want to have some fun? Have an SC and a DC on the same place. You would have to keep your wits about you or end up driving through a closed gate while reaching for a clutch handle. CASE engineers put the hand clutch levers where ever they felt like, depending on the year.
DKase
07-03-2007 20:22:46
 Re: sc hand clutch in reply to BarryfromIA, 07-03-2007 19:33:05
Right or left hand clutch is no problem. The problem comes with the old D's and the newer D's. Old ones you push on the hand clutch to release, and the newer ones you push on the hand clutch to go! The crank on my D has been bent up more than once.
