seperating an SC
911oldschool
07-01-2007 15:27:58
I Am finally getting to the point were I can work on my Chistmas present... I Borrowed an Engine hoist, and removed everything in the way.(basically stripped the tractor), supported under the torque tube and placed the engine in a "cradle", lifted the cradle just a hair to seperate the block from the tube... NO luck. After working for about and hour I have 1/8 of an inch between the to surfaces. All the perimeter bolts are gone. HELP!!! WHAT AM I MISSING!!!! probably common sense!
gary tomaszewski
07-02-2007 06:42:50
 Re: seperating an SC in reply to 911oldschool, 07-01-2007 15:27:58
I'm confused by "torque tube". SC doesn't have one. DCTom is correct, remove pulley brake assembly not just disconnect from hand lever. Use 3/4" x 13-13/16" splitting dowels in the 3/4" holes and a jack under "transmission case", block rear wheels, tranny in neutral, push front end away from rear. Best I can remember. Good luck great old tractors.
911oldschool
07-02-2007 15:30:58
 Re: seperating an SC in reply to gary tomaszewski, 07-02-2007 06:42:50
sorry about the terminology... new to this.
Evidently the input shaft is stuck to the throwout bearing!?
911oldschool
07-02-2007 15:02:10
911oldschool
07-01-2007 17:26:15
the tube and the motor wont slide.... have pried about 1/8" gap between them, is there something about the throwout bearing/arm?
wilson
07-01-2007 17:10:28
use splitting pins and slide the motor fordward
dctom
07-01-2007 15:36:58
DISCONNECT THE HAND CLUTCH LINKAGE SO THE CLUTCH YOKE CAN GO FORWARD AND LET THE THROW-OUT BEARING OUT
911oldschool
07-01-2007 15:51:50
 Re: seperating an SC in reply to dctom, 07-01-2007 15:36:58
sorry, went back and looked at the manual... the clutch linkage appears to be external... and thus has been disconnected.
911oldschool
07-01-2007 15:45:59
Forgive me... I am doing this on my own with no experience. would I disconnect the linkage at the lever or in the tube? can you describe what I might expect?
