I have a Mess
Jeff McBride
06-30-2007 13:20:35
Finally got around to pulling the head on the 48 sc to find out why it was missing. When I tried to pull the head it was stuck. Some ace mechanic had put blue permatex on the head gasket. Oh no i thought. Futher inspection revealed the block had been cracked between #3 and #4 cylinder and welded. It was was welded very poorly at that. Good thing I bought a parts tractor.
C. Amick
07-02-2007 09:23:11
 Re: I have a Mess in reply to Jeff McBride, 06-30-2007 13:20:35
I would first try repairing it again. If you can get it built up and smoothed up the head gasket should seal it off. Can you grind it and fill it with some JB Weld? Put some copper spray on the head gasket and it may seal it off.
ILikeCase
06-30-2007 23:27:20
Remember the Murphy's Law of Parts Tractors-All parts will be in great shape EXCEPT the ones you need.
