970 hesitates when letting out on clutch
mshultz
06-29-2007 08:02:08
Our 970 w/powershift has just started hesitating once in a while when letting out on the clutch - sits there like you're out of range and then suddenly jerks to move. Guages read the same as they do when it works correctly - just a slight drop in pressure before bumping right back to normal. Any hints as to what the problem could be? Just replaced PTO clutch disks and brake a month ago - could it be related?
Thanks!
Walt Davies
06-30-2007 06:32:21
 Re: 970 hesitates when letting out on clutch in reply to mshultz, 06-29-2007 08:02:08
Sounds like a sticky valve in the system without a manual I'm just guessing but look at your manual to see what valve opens when you shift it.
Walt
