1947 SC Case
Edgar Christian
06-28-2007 20:17:14
The tractor overheats. Should it have a thermostat? Have gone through the raditor and water pump. Were there different size sprockets in the rearend to make it go faster? I need a head light blub.
burdock
08-21-2007 19:53:18
 Re: 1947 SC Case in reply to Edgar Christian, 06-28-2007 20:17:14
My 1949 sc has no thermostat in the upper hose...are they available?
burdock
08-21-2007 19:52:26
C. Amick
06-29-2007 09:19:10
If you have a thermostat, it would be located inside the top radiator hose. It could be the water pump is bad. Remove the radiator cap while running and observe the coolant circulation. There should be a lot of swirling.
