David Brown 1200 Head Installation
Phil/PA
06-28-2007 08:21:55
I"m putting my David Brown 1200 diesel engine back together after being apart for a long time. Problem is there are several different types of head bolts. It has bolts and two different length studs. For the studs there are nuts, closed ends caps, and open end caps and I don"t remember where they all go. I took pictures which helps me reconstruct some of their locations but not all of them. Does anyone have a manual, illustration or something that would tell me what goes where. I have the I&T Service manual which give me torques and torquing sequence but that"s about it. Any help would be appreciated.
Elmer
06-29-2007 14:18:20
 Re: David Brown 1200 Head Installation in reply to Phil/PA, 06-28-2007 08:21:55
1200 block is different from 1210, 1410. On the 1200 block you will notice that there are recessed stud holes between cylinder 1 and 2, and two more recessed stud holes between cylinder 3 and 4. The four longest studs go there. The bolts go along the left side of the head. the capped nuts(long) go along the right side and then the row along next to the first. the open nuts go next to that(center). You may have two long open nuts which go between injectors Hope i described this to you good enough to understand!
Phil/PA
07-02-2007 07:38:31
 Re: David Brown 1200 Head Installation in reply to Elmer, 06-29-2007 14:18:20
Thanks.
lee cramsey
06-28-2007 20:52:54
I have a 1410 that I rebuilt last year. I purchased all of the manuals for $240.00. I have the parts book also. I will look for you. I can even look on my tractor. I am pretty sure the 1200 and 1410 and 1212 are the same engine. Someone may correct me on this though. If you call me it will help me remember. I have a 3 day weekend so I should be able to check for you. I'm in Southern Illinois.
Cell phone # 217-343-0413. Call anytime, Lee
