questions on 730 case
Rony
06-27-2007 12:28:19
Been running my 730 EH w/ COM on a mounted sickle mower - love the way it works other than having to start. Is it ok to rev engine up and let out on the clutch like a normal tractor or do I have to start in idle - If I start in idle i tend to plug up or not get the grass to fall the right way. Manual says to let the clutch out slow but it still jerks hard - just don't want to ruin something. Also I have original case couplers and I think they're wore - Hydrolics will work fine and then only one hose will jump (lift for bar cylinder won't move) unplug and release pressure (jam down on tip w/ pressure) plug in and it works again for awhile - any help with the hydrolics would be appreciated as well -This is my first year using this tractor usually use 300 roundnose w/ triple range no power steering -- the 730 is 10 X easier when its working -Thanks
comfortking
06-27-2007 19:08:40
 Re: questions on 730 case in reply to Rony, 06-27-2007 12:28:19
Try running your tractor at half throttle in high first (fifth) Concentrate on letting clutch pedal out very slowly. There is a way to grind the spool to make this possible, try what I said yours may already be done. I use an 800 gas on a batwing finish mower and I can let it ease in a full throttle.
triplerange
06-27-2007 18:10:40
I know what you mean about mowing with a com. Try standing on the brakes hard while letting out the clutch. Then let up on the brakes slowly. You still may have to slow the rpms a little.
