Can still be boom seals
Roger (mi)
06-26-2007 08:35:53
Some settling of the boom is the nature of the beast. That's why there is a boom lock or chains to hold the boom up. Even though the boom is working properly, the boom seals can still have seepage. Poppets? There are secondary reliefs on the valve spool for the boom (other spools have their reliefs too). It's unlikely that serious leakage will occur there unless there is a broken relief spring. Valve spools wear and will have some internally seepage. When it gets excessive, the valve spool will need to be replaced. Replacing a valve spool is a good day's project. Consider replacing the boom seals first. Even so, don't expect the boom to stay up over night.
Dennis Koelling
06-26-2007 17:22:25
 Re: Can still be boom seals in reply to Roger (mi), 06-26-2007 08:35:53
Thanks so much for your reply! You have a great point, in that the boom piston seal could still be leaking, perhaps in one direction due to the design of the seal. Hope to hear from you again in the future.
td5doug
06-26-2007 19:49:18
 Re: Can still be boom seals in reply to Dennis Koelling, 06-26-2007 17:22:25
Probably just seepage past the seals when the system is static. I just recently rebuilt the swing tower & all the cyls on my 580B. One of my stabilizer cyls will slowly weep down from the up position over 4-5 days, Sit the machine up on them & that same stabilier will hold position indefinetly.I believe the seal design (V rings) need a bit of pressure behind them to seal tightly to the cyl bore.
Dennis Koelling
06-27-2007 15:12:13
 Re: Can still be boom seals in reply to td5doug, 06-26-2007 19:49:18
I believe your point about pressure on the piston seals is accurate. I just remembered, however, about an important fact about double-acting cylinders: unequal volume on the rod side of the piston vs. the opposite side. The piston cannot [weep] to the retracted position because the bolt side of the piston has more volume than the rod side. This would explain how the piston would leak one way and not the other. Thanks so much for your reply!
