In need of pushrod for 1952 Case SC
DewayneP
06-26-2007 05:25:48
Hello all. I just found a bent pushrod on my 1952 Case Sc that I use for brush hogging and snowplowing. I have a stuck valve that I will take care of when I have the head redone, but I need a pushrod to replace the bent one. Does anyone have a line on these. I only need one. I have called my local Case dealer and gave them the part number out of the parts manual I have and they say that part is no longer available. Anyone know where I can get a replacement or if there is a new number that supercedes the old one? Thanks in advance.
Jeff McBride
06-29-2007 22:09:47
 Re: In need of pushrod for 1952 Case SC in reply to DewayneP, 06-26-2007 05:25:48
If you can't straighten it send me an email. I have 4 or 5 extras. CHEAP
DewayneP
06-27-2007 10:57:51
To Be honest with you, I never thought of just straightening it. I have had a couple of leads on some used ones, so I will probably get a couple used ones and keep the bent/restraightened one for a spare. Thanks for the help.
C. Amick
06-26-2007 09:07:50
If you can't straighten it, Don Livingston or John Saeli should have one. Email me and I will give you their contact info.
Glenn F.
06-26-2007 06:54:23
How badly it bent? I've straightened/re-used some that were bent pretty bad.
Glenn
