730 Main bearing
jcmarleau
06-25-2007 08:09:16
would anyone be able to help me identify main and connecting bearing on a 730 if they are standard or else. the number on the back of the main bearing insert is D.A.B 7431 A and the number on the connecting rod insert is D.A.B. 7430 A. thank you for the help jc
george md
06-26-2007 00:07:07
 Re: 730 Main bearing in reply to jcmarleau, 06-25-2007 08:09:16
JC,
DAB used the FM numbering system with some
changes. The rod bearing #'s in FM and the individual main bearing #'s in fm all started with a 2 , dab changed the 2 to a 7 ,so your 7430A is the same bearing as an fm 2430 rod brg,
and the 7431A individual main brg is the same as
an fm 2431 main brg that is used positions 1,3,5.
The aftermarket uses the same brg # for all
sizes ,but has the standard or undersize either
stamped or printed on the back of the brg . The
only exception to that was clevite about 30 years ago (only for a few years) used a color code on
the edge of the brg about midway around ,that idea was a flop. The other way to find what size the brg is would
be the measure the brg wall thickness , that dimension is given in the bearing catalogs.I have catalogs from several brands if you need the
info.
george
