exhaust manifolds
INCase
06-24-2007 10:40:58
can anyone tell me if the exhaust manifold from a 730 will fit on an 800. From what I can see it looks very close other than the ports are bigger but the stepped ferrels look like they still fit in the head ports. Won't be able to line them up for a couple days Will need a couple new ferrels too. Thanks for the help.
Jim B
06-24-2007 21:22:10
 Re: exhaust manifolds in reply to INCase, 06-24-2007 10:40:58
I can tell you for sure that a 730/830 Gas exhaust manifold won't fit a Gas 800. Been there done that! Not sure about the Diesel. But the Case part numbers are different for both Gas & Diesel comparing 730/830 to 700/800.
Looked for a replacement 800 Gas manifold for too long. Most available were also junk. Aftermarket has not yet produced. Most likely too little potential sales to build the tooling.
I finally gave up and bought an aftermarket 830 Gas manifold because it "looked" like it should fit the 800. Well it fit the heads OK, with the offset ferrells, but it didn't mate with intake manifold. The heat chamber is different and the offset to the head mounting plane is different. Wasted $175... anybody need an brand-new 730/830 Gas exhaust manifold?
We fixed our 800 Gasser by replacing both intake and exhaust manifolds with a used 830 assembly. Had to ream-out the carb flange holes for the larger 830 studs and revise mounting of the air cleaner upward to fit the different carb location. Also had to machine/make new ferrells because the Case ones didn't fit either.
INCase
06-25-2007 06:16:41
 Re: exhaust manifolds in reply to Jim B, 06-24-2007 21:22:10
Thanks Jim! I have a 730 assembly that I could use. I thought I had heard they wouldn"t interchange but couldn"t really see the differences when laying them together. Which Ferrels did you have to make?? I"ve got 1 intake with a step that "appears" to fit but not the others. I thought I was ok on the 800 manifold but the #1 is pretty badly burned/rusted away due to being run with out ferrels/gaskets. #4 isn"t real good but could be fixed maybe and would also need to patch the cracks in the clamp areas where they crushed it tring to get the thing to seal. Thanks again for the help.
Jim Baxter
06-25-2007 20:54:56
 Re: exhaust manifolds in reply to INCase, 06-25-2007 06:16:41
For our 800 Gasser... I had to machine/make all six of the ferrules. Intake is, as you may know, different than the exhaust. Perhaps the reason the new Case ferrules didn't fit was because the 830 assembly I used was badly rusted at the inlet ports. I needed to use a hole saw to remove the embedded/rusted-in ferrules. Took quite awhile of lathe time to make em'. But what better thing to do in the winter and you have a bad case of cabin fever.
Is your 800 a gas engine? Since the intake and exhaust are bolted together at the heat chamber on a gasser but not on a diesel it may be much simpler to use a 730/830 exhaust manifold for an 800 diesel.
INCase
06-26-2007 05:57:53
 Re: exhaust manifolds in reply to Jim Baxter, 06-25-2007 20:54:56
Its a gas engine. I looked again last night. I see that the 730 intake manifold to Carb is shorter. What did you do to get the tube from the carb to the air cleaner? I like the cast alum. intake pipe as I don"t think the 30 series hoses are available but it may not fit with the 30 series manifolds. I gues I could "adjust" the position of the air cleaner. Thanks.
Jim B
06-29-2007 05:19:38
 Re: exhaust manifolds in reply to INCase, 06-26-2007 05:57:53
Yes, I liked the cast aluminum inlet tube also. So I adjusted the air cleaner upward. Thought about it for a long time and came up with a simple 3/4" thick adapter plate. From-the-factory my air cleaner was adjusted outboard 3/4" at the mounting bolts using tubular bushings, I believe to make it clear the steering shaft. The adapter plate I fabricated maintained this position but also moved the air cleaner upward about 1", if I remember right. As I said, it's a 3/4" thick plate steel and approx. 3"x5". Two hole patterns were machined thru it. One pattern mounted the plate to the engine block, with countersunk holes for bolt clearance to the air cleaner. The second pattern was drilled a tapped for the bolts mounting the air cleaner upward. Used the stock air inlet tube and rubber hose coupling.
Send me an Email which would give me your Email address and I'll send you some photos if you want.
