SC spark
Jeff McBride
06-21-2007 21:22:01
I am trying to find out why it is missing on the #3 cyl and when I pull the wire off it knocks the fire out of me (with leather welding glove on) None of my other tractors will shock me. When you pull a wire off not only do you get shocked you get a nice pretty blue ark from both + and - terminal to the center of the coil. Also which ever wire you pull off it sparks at the distributer at that wire. Wire = plug wires
Is this normal? and if not whats up?
C. Amick
06-23-2007 18:59:57
 Re: SC spark in reply to Jeff McBride, 06-21-2007 21:22:01
Could the distributor cap be cracked? Look inside the cap to see if you can see evidence of where it has been arcing across. Are you using solid copper wires? I believe I run Autolite #296 spark plugs in my SC's.
