steel wheel to rubber
pasbonbasile
06-21-2007 12:00:42
thinking of going to rubber from steel on an LA i just got and was wondering if it would be better to make cut-offs or is there some spoked rubber tire wheels out there? I like the looks of the spokes. any help from y'all? ideas?
Jimmie D. Phelps
06-22-2007 21:23:52
 Re: steel wheel to rubber in reply to pasbonbasile, 06-21-2007 12:00:42
I have a 1929 L that has cutoff"s on rubber..but they are bad(rusted out).. I would like a set of full steel that would fit a 1929 L both front and back..If I knew the price I could than decide if it"s worth it. Two years ago a set came up at aucton and I bid them up to what I thought I could afford. The Guy that bought them was from KS and he told me after the sale he was going home with them no matter what the cost.
pasbonbasile
06-22-2007 04:48:31
Hey Gene, how can I get in touch with Joe Peeper?
Gene Dotson
06-22-2007 14:27:14
 Re: steel wheel to rubber in reply to pasbonbasile, 06-22-2007 04:48:31
Joe Peeper
9320 W. Purdue
Enid, Okla 73703
580-541-1949 is his cell No.
He posts on here some and usually follows the forum and may get in contact with you. Has a lot of L and LA parts.... Gene
russ hamm
06-21-2007 13:02:06
Those wheels will fit an L also, i think. Don't cuttem, please. Not worth a mint, but i bet you could find somebody that would trade good wheels, tires, and all for your steel. Advertise and see what happens.
Gene Dotson
06-21-2007 12:50:05
The spoked rims from an "L" will fit on the LA. I sure wouldn't cut up the steel wheels. They are worth mor then you paid for the tractor.
Joe Peeper in Enid, Oklahoma can probably fix you up with an early set of spoked LA wheels... Gene
Tom Railsback
06-21-2007 12:39:18
Please do not think of converting those wheels to cut downs; they are extremely valuable.
Steve Putman
06-22-2007 05:40:36
 Re: steel wheel to rubber in reply to Tom Railsback, 06-21-2007 12:39:18
I have been slowly (there are a lot of other things on my list) converting my 1930 L back to steel from the cutoffs which it had when I got it. The front steel wheels are on, so the cutoffs are available now. Wheels are good cutoffs, but tires are cracked - probably would work for a while, but would eventually need to be replaced. Would be happy to sell you those - don't know what is reasonable, and don't know what it would cost you to get them from Delaware to wherever you are. The rears will be available too, but not until next summer given my current rate of progress.
Please don't destroy your set of steel wheels. Somebody will use them for a restoration.
