530 PTO seal removal
Swampcat
06-20-2007 10:40:45
I've got a '64, 530, gas with a leaking pto shaft seal. I'm no mechanic and I'd like to know how to remove/replace the seal. There's a snap ring according to the IT manuel. Can I get the seal out by just removing the snap ring? How do I grab the seal to get it off?
Thanks in advance for any help.
Swampcat
06-21-2007 10:04:59
 Re: 530 PTO seal removal in reply to Swampcat, 06-20-2007 10:40:45
Thanks, JGarner...it is the standard version. I'll give it a try.
JGarner
06-21-2007 15:09:17
 Re: 530 PTO seal removal in reply to Swampcat, 06-21-2007 10:04:59
I did this on my 630, same parts as your 530, and its real easy. Hope you don't have the same problem I do. My shaft is so pitted under the seal that it still has a fast weep.
Again, check out the CaseIH parts search site, real good exploded drawings. You will see what I am talking about. My e-mail is on if you need further dialog.
JGarner
06-21-2007 06:02:17
If its a standard PTO version there is a cast iron keeper that bolts to the PTO housing with 3 small bolts and slips over the PTO shaft. Remove the 3 bolts and take off this little cover, it holds the lip seal. Lay it suspended on the bolt "ears" outside surface up and stick the biggest socket (1 1/8" or so works well) you have on the lip seal housing and drive it out. Take it to NAPA for matching and get a new one and reverse the order of disassembly.
If you have an independent PTO you have to remove the complete cast PTO housing and the seal is an O-Ring that sits in groove on the bearing.
Take a look at the CaseIH parts site for an exploded parts break down, this will help.
