CASE???
Tim Jeepinit
06-19-2007 13:33:01
I just obtained a Case I think its a VAI. Do you know of any direct links that would be able to give me some information. Such as year, model, wiring, 6volt/12volt, direct positive/negative.
This tractor has been sitting for about 12 years. It currently isnt running but its in real nice shape. I am thinking it was a parade stomper it has a aruga horn under the hood. I picked up this tractor for a song and was hoping to tinker a bit and get her all fixed up!!
Thanks in adavance!!
Tim Fisher
[email protected]
Tim jeepinit
06-21-2007 13:04:51
 Re: CASE??? in reply to Tim Jeepinit, 06-19-2007 13:33:01
third party image
Let me know what you all think.
Link
JGarner
06-23-2007 20:56:53
 Re: CASE??? in reply to Tim jeepinit, 06-21-2007 13:04:51
I think you need to repaint it. The Desert Sunset color did"t start being used until the number series tractors and carried through the 30 series. The V series, S series, Dseries, and LA were Flambeau all over. Otherwise nice looking little tractor!
C. Amick
06-21-2007 09:25:16
I've pasted a link to a web site below that you may find helpful.
watsonsgotit
06-20-2007 12:54:08
The VT casting numbers signify a VA series tractor. The tag that you are talking about should have more numbers stamped in it. You may have to remove old paint to find them.
Tim Jeepinit
06-20-2007 13:18:19
 Re: CASE??? in reply to watsonsgotit, 06-20-2007 12:54:08
Thats just it....There is not alot of old paint. The tag is clearly visable and cleary stamped only 1810. This makes no sence to me. I can not figure out her year. Perhaps if I took a few pictures to share someone could help me!!
Tim
Paul f
06-20-2007 06:12:54
It came from factory as 6 volt Positive ground...many were changed over the years...double check by looking at the coil, if the wire from the terminal marked + goes to distributor it is still positive ground.
amo
06-19-2007 17:51:00
go to the left of here under serial numbers and it will give you dome information. Also go to web site tractor.com for more. Good luck with your case.
watsonsgotit
06-19-2007 14:55:56
Your VAI was factory equiped with that horn. It was 6 volt. subtract four from the first two numbers of the seven digit serial number to find the year.
Tim Jeepinit
06-19-2007 18:06:37
 Re: CASE??? in reply to watsonsgotit, 06-19-2007 14:55:56
I can not seem to find the serial number. There is a stamped plate that shows where it was manufactured with the numbers 1810 stamped into it. There are alot of casting of part numbers all starting with VT all over it. But nothing I see starting with 46-59. I need a voltage regulator, for starters and a battery...then let the fun begin!!
