The tractor was running only fair and idling rough but brush hogged fine before being down a year for a intake manifold to be rebuiltPut a kit in the carb to smooth out the idle since getting the tractor running again, and the tractor idles smooth and runs and drives fine until trying to use pto to brush hog. As soon as the tractor gets into any grass it slows down and looses rpm until either it dies or I pull back on the clutch lever. I do not hear the motor changing rpm by the govenor like it used to If I disengage the pto it will drive through the deep grass fine. If I sit in one place and have pto engaged the brush hog rotates fine so I do not think it is the brush hog. I also serviced the brush hog and everything on it is lubed and turning properly. Last year I was cutting small sapplings 12 feet tall and this year I cannot cut grass 18 inches tall without stalling. It acts like the govenor is not working right or something, is it possible for a govenor to freeze up from sitting and not work? It had really old spark plug wires and I replaced them with modern auto wires I had in the shop, I put new spark plugs in it same size, same gap and I cleaned the contacts and rotor button in the dist cap. I checked the points (someone had changed it from magneto to dist sometime in the past) and they looked fine. I cleaned the oil bath air filter and put new oil in it. I would appreciate some suggestions as to what else I can check to get the power back up or whatever is wrong. Any suggestions appreciated!
