Hubs for DC rear axel
wilson
06-16-2007 19:39:15
I am searching for a set of SIX hole hubs for a 2 &7/8 rear axel. I have been told they exist. I wish to put C C steel on a DC These would be the type with u-bolts to secure to the axel. Thanks Bill
toomanycases
06-18-2007 11:42:54
 Re: Hubs for DC rear axel in reply to wilson, 06-16-2007 19:39:15
Rich???? maybe tomorrow, but don't bank on it! Although the way prices are going on some parts it might sooner. But it sure will be a lot of work. Chuck
Jim McVay
06-17-2007 13:07:52
Why not change the axles to some out of a DO with the 6 hole flange. We have a pair in a 39 DO
wilson
06-18-2007 15:36:18
 Re: Hubs for DC rear axel in reply to Jim McVay, 06-17-2007 13:07:52
do you have the 25 tooth sprockets???
wilson
06-17-2007 14:32:42
I must be just getting lazy as I did not want to take all the hydrolics, live pto, and whole back off the DC. You are probably right the flanged axels would be fine. Do you have the 25 tooth sprockets from the DO? The axels are splined arent they?
Camboted
06-17-2007 00:50:44
Bill,
I've used Russian, Belarus, hubs. They actually work pretty well. Belarus uses a cast hub with a cast cap rather than a U-bolt, takes six bolts three on each side of the axel. I can buy you a new set, for like $80, but what I don't know is if the holes will line up for yopur CC wheels???
wilson
06-17-2007 08:10:28
 Re: Hubs for DC rear axel in reply to Camboted, 06-17-2007 00:50:44
sounds good is there only 6 holes around the flange where the wheel bolts on??? I will try to look at some belarus tractors and see if they will work. How many dc front blosters and radiator shells do you need now as I am selling some (a lot) of parts to clean up also there is one front bolster and radiator shell laying with the 900b when sonny picks it up Bill
Camboted
06-17-2007 15:52:11
 Re: Hubs for DC rear axel in reply to wilson, 06-17-2007 08:10:28
Bill, I'm ok for now with the DC radiator and base parts. Thanks!
Tom Railsback
06-17-2007 14:43:21
I'll eventually need a pair of radiator sides and a bottom tank.
wilson
06-17-2007 18:18:19
 Re: Hubs for DC rear axel in reply to Tom Railsback, 06-17-2007 14:43:21
I can add that rad to you pile of items!!! Now let me think Radiator ,intake and exhaust manifold, air cleaner knob, wishbone for standard wide front. Tom you are going to have to bring a trailer, Oh well as long as you are bringing a trailer bring me those wheels ,rims, tires ,and blade from montana, I really think we should start one of those e bay stores. Tractor parts old trombones, and possibly a tuba or two!!I might even put my electric truck on the list!
Tom Railsback
06-17-2007 18:48:05
 Re: Hubs for DC rear axel in reply to wilson, 06-17-2007 18:18:19
How quick will we get rich?
